68 RS L30 AA 749
I need to convert my booster to master cyl. push rod from short to the longer one. Is it just a matter of pulling the old out and inserting the new ? Can the booster remain on the car ? Any other precautions ???
Yes it just pulls out of most Moraine boosters. Kelsey Hayes boosters don't pull out.
Usually it can be done with your fingers, some take a pair of pliers but very little effort. There is an O ring on the rod.
There is also a spacer you can throw into the master cyl to take up the extra space. Baer includes them with their kits, use as needed.
David
68 RS L30 AA 749
Thank you David, I appreciate your input. Yeah, mines 11" Delco/Moraine....think it's off of a mid 70's full size.. not sure. I pulled a little with my fingers and no movement...just didn't want to get the pipe wrench out w/o knowin what I'm doin first ;) So, hopefully a new O-ring won't be hard to find. I'm thinkin a slight shot of silicone spray for lube on installation, or something better ?
Thanks again !
