I just installed a complete 4 wheel power disc setup including all new hardlines on my 69 camaro. I bench bled the master cylinder already. What is going to be the best and easiest way to bleed the brakes? I tried one of these one man brake bleeding systems, I ended up pump the brakes several times but did not notice that the tube fell of of the bleeder valve? Do I have to bench bleed the master cylinder again since I pumped the brakes several times with the bleed open? Thanks
