My booster seems to leak; I am looking for some advice on a replacement. Any recommendations for a better more firm and precise feeling booster would be greatly appreciated. Ideally it would be a bolt in but I would be comfortable making brackets and lines if highly recommended.
The brakes on my 68 are 11" fronts from a 71 Monte Carlo and disc rears from a 79 Trans Am. I have been using the booster from the Monte Carlo that had disc/drums. I use the master from the Trans Am with a shallow piston. Just to finish the description I also have braided flex lines and an adj prop valve for the rear.
Thanks in advance,
Vic
Hey Vic, I have a lifetime warranty booster thats actually a GM licensed repro so its all brand new and its a bolt in for your car! They are also show quality CAD plated!
Email me if you need more info!
Matt's
