I just recvd power booster and mc.Changing from man to power disc.Booster and mc came with two rods short and long.Also came with what looks like a spacer that goes in mc.Which rod do I use and,does the mc and booster need a gasket between them?
"Ford Power Joke" is what GM folks refer to the "Ford Power Stroke" diesel engine as...
When I did mine, I used the spacer in the mc and the short rod. I felt like the brakes were dragging and shortened the spacer .030-.060 at a time.,it is easier to add washers if you are way tight. The mc should go all the way on the booster without any resistence, you need a little bit of free play, but not much
