Mike -
Do you have the complete 69 setup, including the mount assembly? If so you should be fine.
67-68 had one mount assembly and one brake pedal curvature, and 69 was different. The difference in the mount assemblies is some bracing and where the brake light switch mounts; a 67-68 brake pedal has more curve, so if you use it in a 69 mount assembly, I think the brake pedal is lower than the clutch. I think a 69 pedal in a 67-68 mount would be higher than the clutch pedal.
The clutch pedals are the same all three years.
Eric, I don't have the 69 mount, I still have the 68 mount. I will be mounting the brake pushrod into the upper manual hole since I am using a Hydroboost brake system, which I'm not sure would make a difference. I looked at the old auto brake pedal and see waht you mean about the curvature. Oh well, thats what I get for not doing my homework before I buy!
Mike
