So...I have a 68 Camaro and when the headlights are on all four brake lights work...But when I step on the brake I get nothing...I dont want to get rear ended so...can anyone help
Do emergency flashers work?
If they do, check power and fuse for stop lights and check brake switch at brake pedal.
If they don't, jiggle turn signal switch handle, maybe lift up alittle.
All four go out when you press on the brake? If so, it can't be a ground as all the lights ground seperately. Must be a poor positive connection that can not drive the additional load of iluminating the brake filaments. I had a similar problem on another car and it turned out to be corrosion on the fuse clip in the fuse panel. I hit them with a nail file and the problem was solved.
