Your symptom reads like the problem could be the turn signal switch.
Brake light power from the fuse panel to brake sw to turn signal switch to rear/front lights.
Select a turn, and turn signal power from the clip-on flasher enters the t/sig sw and lights flash Other side brake power should still go through the switch.
You might jiggle the t/sig sw handle as the handle is metal and heavy as gravity does its thing. Turn signal switch could be worn out as in the bushing the switch turns on.
