1 - 1 of 1 Posts
This weekend i started installing a Wilwood system on the front end of the car. I put in a master cylinder/proportioning valve setup. It doesnt seem to anticipate the installation of the warning switch block. My AAW Classic Upgrade Kit provides the wire for it. It my plan to get a Dakota Digital RTX for console gauges when it comes out in a few months. I also intend to put a line lock on it. The area around the master cylinder could get a little busy.
To those of you with Dakota dashes, do they supply an indcator for that circuit?
I could leave it off, and i likely will if there is no dash indicator.
I like the Wilwood setup but fitting that block in line between the master cylinder and the prop valve will be a challenge.
1 - 1 of 1 Posts
