WANT TO KNOW IF DISK BRAKES OFF OF A76 NOVA WILL WORK ON A 69 CAMARO A FREIND SAYS THEY WILL BUT I HAVE TO CHANGE PASSENGER SIDE TO DRIVERS SIDE & DRIVER SIDE TO PASSENGER SIDE BECAUSE THE STEERINGING BOX SITS BEHIND FRAME ON A 69 CAMARO WHERE ON A76 NOVA SITS IN FRONT OF FRAME IHAVE BOOSTER & MASTER CYNCLINDER OFF A 69 CAMARO I NEED TO KNOW IF IT WILL WORK WITH 76 STUFF OR DO I USE EVERTHING OFF 76 IF IT WILL INTERCHANGE
David Pozzi has a complete list of brake donor cars on his web page. If it is not on his list I would be willing to bet they won't fit.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
DISC BRAKES THAT WILL FIT FIRST GEN CAMAROS
You can use the spindle, caliper, bracket, or rotor from:
Apollo 73-74
Buick Special 69-72
Camaro 69
Chevelle 69-72
Firebird 69
Grand Prix 69
Grand Prix 70-72
Monte Carlo 70-72
Nova 69-74
Olds F85 69-72
Omega 73-74
Sprint gmc /El Camino 71-72
Tempest 69-72
Ventura II 71-74
They must be disc brake equipped of course. I believe discs became standard in 1970.
Some of the cars listed have the caliper forward of the spindle. You must swap side for side placing the Caliper to the rear of the spindle on the Camaro.And use your Camaro steering arms.
I'm not shure about brake boosters working from every car listed. TheFirebird , Nova, El Camino, and Monte Carlo do for shure.
This is a very complete list.
I've also deleted four piston type from this list.
I have more info on my web page below.
David Pozzi's web page: http://ourworld.compuserve.com/homepages/David_Pozzi/
David
David's Homepage
67 RS 327
69 Camaro Vintage Racer
thanks for your reply to my problem i had looked at information you have at team camaro an saw that brakes will only work up to 74 i didnt think 76 would work because steering box sits in front on 76 nova&in back on 69 camaro
The spindles like the 76 Nova that are cast and don't have the bolt on steering arms won't fit the first gen Camaros.
I have info on my page that shows what you can do to your existing drum brake spindles to make em work on a disc system.
David
David's Homepage
67 RS 327
