Good evening, guys, I put new brakes(disc) on the front of my Camaro, new brake booster, proportioning valve, new stainless lines through out. Rear are the drums. when I hit the pedal I can almost lock up the rear brakes. What do I check?
Re: brakes almost lock up
The proportioning valve needs to be fine tunned so add a little more to the front. Just a little at a time.
when you say add a little more to the front - could you clarify, please.
Which brake design? GM design or aftermarket with integral proportioning /distribution block? If GM design the round valve under the master is a metering/hold off valve, not a proportioning valve. Did you bench bleed the master? Did you put the brake pedal rod in the correct hole? Is the intermediate rod the correct lenth? Is it a disc/drum master?
can you tel me what your previous and current setup is and is this all stock stuff or what kit did you buy thanks
