i just installed new clutch/brake pedal bushings in my 69 z28. now whenever i step on the break the passenger side front directional goes on, it does'nt blink it just goes on. The directionals work fine and
there are no other problems just this annoying little light. I think it has something to do with the turn signal switch
but the switch is only 2 months old.
Dave
Your turn signal wires run down the top of the column. While you in there, maybe you pinched or skinned a wire. Try moving the wires around and unplugging,replugging wires, maybe loose connection.
Bill
PitStop: Thanks for the help I moved the
wires around and everything now works normal. I thinks it was the wires going to the turn signal switch. But hey who cares it
works.THANKS
