1 - 2 of 2 Posts
Neither one of my bright lights work I dont know if there is a something messed up with the wires or what. Is it common for both of the lights to stop working.
Light switch at the bottom of the steering column may need adjusting.
Loosen the hardware at either end of the switch and select high beams, move the switch until h/beams come on, then tighten hardware.
Test selecting low/high beams to make sure the switch works.
With the other problems you've listed in other posts, I suggest you get a Haynes manual for the year/model of car to use a valuable reference guide. Better than nothing at all.
Welcome to the club, Carmen.
1 - 2 of 2 Posts
