1 - 12 of 12 Posts
i think its the egr not sure but while i was installing motor one of the chains from the hoist snapped a port that is located behind the throttle body on the drivers side.
do i need this part and need a new intake?
or can i epoxy the hole closed and call it a day?
thanks
You don’t need it. It’s the evap solenoid. Epoxy it up.
Don
Reactions: 130fe
Don
thanks Don
u have any recommendations on what to use?
I think any two part epoxy that is thick enough it won’t fall in the hole should work. Temperatures are not extreme.
Don
Should be fine.
Don
Discussion Starter #8
Im thinking of roughing it up and taking throttle body off to see if i can get behind it too
Anyone know what type of plastic it is?
I can use 3m plastic repair
Seen where guys used a soldering iron to "weld" up cracks and holes in plastic intakes ;)
Discussion Starter #10
Seen where guys used a soldering iron to "weld" up cracks and holes in plastic intakes <img src="http://www.camaros.net/forums/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Thats awesome
I can use the piece that brroke off as a filler :)
Discussion Starter #12
Used a woodburning kit with a small flat triangle paddle
1 - 12 of 12 Posts
