I have a new HE260h Comp cam in a totally rebuilt 454.
I used a new autoZone fuel pump rod.
Should I buy a bronze tip rod from Comp - or does it matter?
Thanks....:thumbsup:
Fred,
The stock rod should be fine with that cam. The bronze tipped ones are more for the billet roller cams.
I got into this on a cast roller, Comp said the brass tip is also used when you run higher pressure / volume fuel pumps. I would stick with the stock push rod if you are all stock.
