68 camaro, I have wires overheating and burning up that come off the alt. what could it be ??????????
thanks Doug
wire size to small? bad connection? hooked up incorrectly? grounding out somewhere? when troubleshooting, the first rule of thumb is to look for the obvious. then look again because it was probably so obvious you didn't see it the first time.. i hope this helps a little if any..
gues what the condencer in the alt was loose ans shoting out inside the alt. Ps I still can't get it to charge.
At this point, I would suspect that the diodes went away inside the alternator. They don't tolerate much abuse!
Rick Dorion
69 RS Conv,355,M20,4.10's
