hey guys, this is only my second post, I just sold my '68 Chevelle tonight and am working toward a '69 Camaro around April. The car will be about a 95% strip 5% street car, I know because of the higher demand I am going to look for a base model car, because I know the original SS cars and Z28's go for a lot more regardless of the current state. Any tips or hints you guys can give me? I am basically looking for a base '69 dusk blue on black, with a 355, Turbo 350 12 bolt that runs low 12's, I am gathering parts to build a low 11 second motor for the car eventually. I will probably have around $8,000 to spend come spring time drivetrain and suspension are obviously my prime concerns, Im sure it will be a car that needs some interior work and is primered, but any help you guys could give me would be great. Thank You very much.
Jim
If you're looking for a car that's 95% strip, and mostly interested in running 11's, I'd focus on a good clean body and straight subframes. Dusk Blue is fairly rare...less than 5% of 69's, which equates to about 10,000 cars or by my calculations means about 2500 cars left today +/-. You say you want a non-Z, non-SS, 350, 12 bolt and a 350 TH. You just described an LM-1 car. There are a few out there, but they're pulling almost as much as SS-350's.
What I'd do if I were you, is get a six-banger car with a good clean body...with less than 5% rust. Drivetrain is irrelevant. You'd rather it didn't run, so it'd drop the asking price. If possible, make sure it has all the trim. Trim can add up in a hurry as I continue to learn the hard way. Get it painted the color of your choice with base and clear poly. Purchase a 12 bolt,..fit it with posi and gears of your choice (4.10's would be start for a high revvin' 350 that pulls 11's). I've seen 12 bolt housings in the $500 range. 350TH are readily available used...you could get one that runs well for $200 at most any boneyard. Have it built to your needs for another $500. Then pick you a crate 350 or shortblock and build it to about 400 or 500 ponies. Beef up your subrames so you don't twist the car in two, then blast off!!!
Estimate: 11.9 et for $11,900
Car....$3500 (may be better deals)
12 bolt (built)...$1000
Crate...$4000 (several in price range)
Tranny (built)...$750
Paint...$1000 (not show car, but good)
Wheels and tires...$ 800
Other...$1000 (stuff like, brakes!)
Bad *** Camaro that runs 11.9 et...$11,900 (rough estimate).
Then come to Ausitn...pick up ol' Sleepy...pin his eyeballs to the headrest. Watch Sleepy smile! Good luck!
Related Threads
Team Camaro Tech
2.4M posts
83K members
Since 1998
