Here is my situation,
69 Camaro front disc and rear drum, power
installed new power brake booster, master cylinder, metering block, proportioning valve and front hard and rubber lines.
i bench bled the master and bled all 4 wheels starting at the right rear, left rear, right front then left front.
during bleeding I got to the point where only fluid was coming out. Not my first time bleeding brakes.
At no one point did the pedal stop going to the floor.
If I hold something between the booster and the plunger on the back of the proportioning valve the pedal no longer goes to the floor.
Am I doing something wrong or did I get a bad master?
