Here is my setup:
350 4blt stock bore
Edel 600cfm Elec choke
Edel Perf RPM intake
HEI distributor,
Comp Cams 270 H....050 224/224 470''/470'' 110lsa straight up
Iron Heads 202/160 76cc chambers no port work but decent valve job with 10.2:1 CR w/ Speed Pro .200 Dome forged pistons
forged bottom end, 3 core radiator, Hooker Comp Headers, Flowmaster Dual 40's, TH350 really built good, 3.23 rear 10bolt open 8.5''
Here is what i want to change:
Heads- Dart Pro-1
200cc intake 64cc comb chamber 2.02/1.60
Cam- One of these two hyd. rollers
224/230 502/510 @ .050 110 lsa
230/236 510/520 @ .050 110 lsa
what do yo think? i kinda dont wanna get a stall so maybe the first cam? thansk a lot
any of the cams mentioned (including the one you're running) could probably benefit from a slightly looser than stock converter.
Also, swapping from those 76cc heads is going to boost your compression considerably and I don't know if you could get by on pump gas with either of those hydro rollers if you're running over 11:1 compression if that is a concern.
Anyway, all that aside I'd say go with the second cam. It should give you a decent idle and good power from just a bit over idle through redline. The first cam would be nice as well though. Time for a tire barbeque! :D Good luck.
I have the first cam you mentioned(224/230) and it has a killer sound to it. I get 8" vac at 5-600 rpm and 12" at 800rpm. I think you'll be happy with it It's the comp cams 08-423-8/ xr276hr-10grind
Mike
thanks for the replies guys
Mike, do you have any et/dyno papers on what that cam can generally do? thanks again
Adam
i might get a stall slightly above 2200
I just put the engine in last week and i'm waiting on a driveshaft. So, no #'s yet
I will say that it sounds killer coming straight out of 3" collectors from 1 3/4 primary tubes. Nice healthy lope, instant throttle response. I think it's perfect in the vacuum respect. The idle's not too high for sufficient vac.
thanks, i know there isnt much difference with the cams so ill prolly get that first one just for the little bit of lower duration. thanks alot, let me know how she runs when shes complete looks great in the pics!
Adam
[email protected]
Discussion Starter #8
thanks mike, not sure if you know but this site also has a link for combo's, under racing i believe on the home page
Adam
