Hi All,
I have 69 air conditioned Camaro with BBC 427, M20, and 12 bolts 3.42 rear end. The engine has edelbrock aluminum heads, air gap intake, 750 DP Holley, and compression ratio 10:1. Car is for fun in the street and rarely strip. Both camshafts are Hydraulic flat tappet. First camshaft i have is the edelbrock 5062 and the second one is customed by G-Straub. Which one is stronger and does not shake the engine too much
Edelbrock specs are:
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 302
Advertised Exhaust Duration: 304
Advertised Duration: 302 int./304 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.527 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Valve Lift with Factory Rocker Arm Ratio: 0.527 int./0.553 exh.
Lobe Separation (degrees): 114
Straub's cam specs are:
Intake Exhaust
Duration @.050” 220 228
Adv. Duration 270 282
Lobe Lift .3130 .3090
Valve Lift – 1.7 Ratio .532 .525
Centerline 105 113
Open Close Open Close
Timing Events @ .050 5 35 47 1
Valve Lash (Hot) .000 .000
Lobe Separation: 109
Overlap: 6
Basic Operating RPM Range: 1600-6200
the custom grind has a better RPM range IMHO.
The Edelbrock doesn't come on until 2500rpm
I prefer cams with low/mid range power vs the high RPM ones. If it is all about the 1/4 mile...than the 1st cam
I have a 327 with an RPM range similiar to your # 1 and it isn't really the greatest for the street. Go with choice # 2
#2 Especially if Straub recommended it. If not, call him.
For what you're asking, I would be looking at grunt so maybe a 4x4 or RV type cam.
As for the "smooth" motor, a wider LSA will help.
I did a quick look and liked this one on a wider LSA 114
So, #2 would be my choice... Straub knows his stuff. I would go with his choice (as it looks like you are) :beers:
Headers or manifolds? If manifolds you can only go so big before the overlap slows it down. Interestingly, something similar to a "modern" L78/LS6 grind (aka 114 LSA) would be one of the better choices with manifolds. If headers I'd tighten it up to 110-112. Also if manifolds the extra exhaust lift of the Eddy cam won't buy you much if anything.
