Pulled the L2220A and 7001P TRW which I believe were 12.5-1 and went with JE 10.4-1 but with mild head shave could be higher. Is this cam going to work well with the lower compression?
The L2210AF pistons are designed to be a bit above the stock CR - 12.2:1 with 64cc heads
Unless you plan on running the engine a lot at high RPMs you might want to consider something besides the solid lifter cam.
I would guess that like me, you wanted to run your engine on pump gas - I went with a full roller Howards cam with the JE pistons in my 327. They're supposed to be 10.25:1 with 64cc heads so in the same CR range as your pistons - my cam is 278/284 with 500/510 lift.
302s produce peak horsepower at higher RPMs than the 327, so you're best bet is to call a cam manufacturer and give them all the details about your engine and how you're going to operate it. They'll recommend what they think is the best grind based on what you want to do with the engine.
