1 - 17 of 17 Posts
I was just going through some old shelves of parts. I came across a brand new General Kinetics' cam for a Big Block Chevy. I do not have the cam card (The end of the box is torn off, guess it fell out at some time. :( ) and I would really like to know what exactly it is.
Here is what I know about it:
It says Holley Part# C2M-294-R on the end of the box that was torn off.
The numbers on the end of the cam are 965703. If I remember correctly this cam was suppose to be a solid flat tappet cam with roughly .550ish lift and I think it was around 230dur @ .050 .
I also found a used Small Block Cam in a box that I know it did not come in. I think this cam was given to me in trade. It has a mark like /74 then under that it has 222430. If I'm not mistaken this is a hyd cam and it had a healthy lope in a 350ci engine.
As I stated I don't know for sure anything except the numbers on the box for the BBC cam and the SBC I am 98% sure these #s are exactly what is on the cam. Any Ideas?
Steve
I added the number off the end of the BBC cam. Maybe this will help
Banned
I'm into older cams big-time and I don't recognize those numbers right off the top of my head?
Sorry,
pdq67
Re: "General Kinetics" camshaft
A quick Google search reveals 'General Kinetics' camshaft grinders went out of business after selling every fifth Chevy owner a cam without a cam card. No one seems to know if they snuck off in the middle of the night catching the last boat to Terra del Fuego; or were bought out by some other company (for example Edelbrock) that needed a cam grinder to complete their suite of businesses.
Read through (not really just glanced to get the gist of posts) 23 pages of "help I've got an old cam and I don't know what it is." requests for help. Unfortuneatly the majority of posts in response were themselves pleas for help as no one knows what the specs are on old cams, but apparently everyone once upon a time removed their 'General Kinetics' camshaft for a better one.
Larger Dave (former Know it all)
I took a G-K cam out of my 327 last year, on the back it had a "grind" number, very recognizeable, cointained "292" and "112", pdq was able to id it, anything like that on yours?
Degree the intake, and the exhuast, that will give you you # @.50 and you can get intake center line as well as exhaust centerline to find out you lobe centers plus you get the lift# as well, no real easy way out, just a little home work involved
Well the numbers on the end of the GK cam are 965703. But other than that just this on the end of the box.. Holley Part# C2M-294-R.
Thank you for trying fellas. I really didn't want to do all the math if it could be avoided. I really thought pdq67 would rescue me on this one. ;) I was thinking of listing it on EBAY if I had some #s for it. I don't think it would really be worth the listing or doing the math as cams similar to this can be purchased for $50.00.
Thanks Again
Steve
Banned
Steve,
Sorry, I don't have all that much G/K BB cam info.
And I do want to say that back in their day, G/K cams were NOT generic cams, but rather very good old-school designs, imho.
They list two SB cams in particular, one, the C1H-270-S, 270/216, 110/?, .454" lift and the other, the C1H-290-S, 290/218, 114/?, .450" lift.
They illustrate wide and narrow LCA theory from back in the early '80's (and I figure earlier). I contacted them and asked what the difference is between them, and I still have a short note back from them explaining that it would take a whole lot longer note to expain the theory behind why they look the same, but will operate so differently.
pdq67
PS., I got my G/K info from the now, long gone Hollywood Sams Auto Parts, Inc., in Detriot, MI.... I first bought the 290 cam and ended up taking it back and getting the 270 one later.. It's in my Nephew's 327 motor that I gave him..
General Kinetics cams nomenclature=
C.=Chevrolet
M= Mechanical
2= Big block
294= Advertised Intake duration with 1.70:1 ratio rocker
a-z letter suffix= modification of original design. More exh dur., changed centerline, changed exh pattern, etc. EXCEPT the "R" series of "Redline" cams. These were "White box" mass produced street cams that you can still buy under a dozen different brand names.
So if you have a C2M294R General Kinetics cam. You have a Big Block Chevrolet, solid lifter cam with 294 advertised duration, Redline series.
Discussion Starter #10
Man you were dead on until you got to the color of the box. Unless I have misunderstood you. This is exactly what is on the DARK BLUE box with RED GK writing on it. Holley Part# C2M-294-R I did notice that under the label I can see there was another label all I can read is 294 though and it wont separate (I tried). Also someone has wrote a 70 with what looks like a sharpie on the edge of the label. Thanks Mike I appreciate it.
I agree I had one in my 69 Pontiac Firebird man that was a stout 400 motor.
C.=Chevrolet
M= Mechanical
2= Big block
Banned
ZZMike,
Do you by chance have G/K SB and BB hy- and solid lifter cam spec's lists?
I'd sure like to have them for my old cams files besides what I do have now from Hollywood Sams.
pdq67
Any idea what time frame they are from? I've got pretty much every hot rod mag dating back to the 50's, and a bunch of old catalogs back to the mid 1980's. No g/k stuff specifically, but I might be able to find an old ad in somewhere.
pdq67 said:
ZZMike,
pdq67
Let me look around and see, that is going back aways and I may have tossed all of that stuff after they merged with Lunati.
Discussion Starter #14
Trravis man I really have no Idea ... late 70s early 80s is a guess.
again
Steve
It was not my intention to bad mouth General Kinetics Cams. And I apologize to any one who took it that way. I was attempting to illustrate that General Kinetics are sitting on shelves instead of being installed in cars.
Since Chevy never installed a General Kinetics cam I am assuming someone else did. Secondarily it can be further inferred that they found another cam that they thought performed better. Otherwise the General Kinetics cam found on the shelf wouldn't have been sitting on the shelf to be discovered now. (Elementary my dear Watson, though what Sherlock Holmes' ability to run has to do with this conversation I will never know.)
There have been two major design improvements in the SBC since the sixties. Heads have been dramatically improved in terms of flow and combustion chamber design. The single most significant improvement has been made in cam shaft design. Now I freely admit that I am a pack rat. I have several rusty old Crane and Comp cams stacked like cord wood in the corner of my garage.
I don't ever intend to reuse any of them in a car (lifters are long gone) and the only reason they are still there is I haven't thought of a good use for them yet (they are too long for coffee table legs, and too short for bar stool legs). Aside from scrap they have only sentimental value as milestones in the ever evolving improvement in sixty foot times or trap speeds.
Had someone shown up on my doorstep in a timely fashion I would have given them the old bump stick had they demonstrated a need for it. That would have suited my scotch nature more than watching them rust away as I do favor recycling (Especially if I know that the combo they have isn't a challenge to my set up: and knowing their cam is a definite plus from a tactical point of view.)
Anyway I am sure General Kinetics made great products once upon a time, and am sorry I couldn't shed any more light on the subject. I do have old Crane, Crower, and Comp cam catalogs that I use for reference from time to time.
Larger Dave
Banned
You are fine Dave!
I was just saying that even though they weren't all that popular back then, they were/are still good cams.
pdq67
1 - 17 of 17 Posts
