Thats it in a nutshell Chris. However if you have serious peel and a run, you may want to take JUST THE TOP off the peel and the run with 800 or maybe even 600 grit. But JUST the top. You will be sanding into next year if you try to polish off the rough stuff with 1200 or 1500, but if you go to far with the 600-800 you will have a tuff time getting the sanding scratches out without going through the clear. Use good paper and a soft sanding block. Do small areas at a time. Use a squeege or the edge of your block often to wipe away the water and check your progress. After a little while you'll get the hang of it and will be able to 'see' just whats done and what needs more work. If the water run off or your paper has any color except the white form the clear it means you went through to the paint...avoid that at all costs since you'll have to re-clear the whole panel and start over. Move up to 1000, 1200, 1500, or even 2000 grit paper to further polish it. Then get a buffer with a foam pad and some medium to light cut liquid polishing compound depending on how far you went with your sanding. Polish at a slow speed and stay away from all corners and edges. Paint is very thin there and you'll polish it right away. Some even tape them off just to be sure. This is also an aquired skill. Just start slow and you'll get it. When you have a beautifull shine with that get some very light polishing compound like 3M's perfectit and finish with that. You should be more then pleased. Don't wax it as it won't be fully cured for quite a while ...oh ya....buy some "icy hot" or something similar for the sore shoulder muscles...:beers:
