I did a search but maybe didn't use the right search terms.
I want to replace all the brake lines (power front disc/rear drum) on my 68. The AIM makes it looks like it could be tricky going under the engine.
For all the experts: can I replace all brake lines while the engine, rear end, etc is still installed?
Yes you can replace them all with the engine in no problem
Reactions: VitaminC and DT
Replaced all mine, as mentioned above , the long one is a booger. Had I selected stainless, it may have been harder to route up into the cowl, fender apron area just below the m/c.
