1 - 8 of 8 Posts
During my restoration of my 68 convertible, I installed a new 3 row aluminum radiator. Can I still use it and just convert to electric fans?
Also, Can I use the new standard fuel tank as well? Or do I need to get a fuel injection tank?
Thanks!
You can use the radiator will have to figure hoses routings and provisions for the steam line.
Tank will work with a Holley Drop is fuel module or you can use an external pump with a 2 line sending unit so you have a return line.
I used a 2004 Silverado upper and a lower flex hose....pretty :noway: but worked.
You can tap the suction side of the WP for the steam line.
The steam vent line can go to the radiator if there is a fitting for it on the radiator. The line can go the water pump. You will have to drill and tap the water pump on the return side. The last way is to plumb it to the top radiator hose.
LS Steam Vent - C&R Racing steam vent kit - Hot Rod Regal
Don't plug the line.
Reactions: bondora68
1 - 8 of 8 Posts
