Looks like i fried my in dash reproduction tachometer, while searching for a charging problem i full fielded my alternator and got the voltage up to 16 volts.
can a tach be repaired, or should i throw it out and buy a new one ( expensive repro @ $225.00)
thanks
Did you already check the wires and circuit board? Maybe even install a temporary jumper wire from coil to tach just to make sure... Isn't there an instrument fuse, as well??? Just spit ballin' here...
yes checked tach input and i am getting 12 volts, i need to check my MSD to make sure tach output is functionnal
Just checking... You measured the tach input by probing the stud and nut above the tach, right? I've never measure it w/ a meter. Didn't know you sees 12V. But I suppose it is some kind of pulsing signal and could be "caught" at the 12V level? Thinking out loud again... lol
