Hi all. I am having a full frame built for my Camaro, and was going to sell the frame and 12 bolt locally to a guy who wants it bad. So is it possible to ship a car that does not roll? Can i build a cradle to make to mobile so i can get it onto a truck? Any web sites on how to do this?
Tyler
<A HREF="http://www.pro-touring.com/featured_cars/tyler_beauregards_68_camaro/tyler_beauregard.htm" TARGET=_blank>
68-LT1-T56
</A>
I've never seen it done, but you could weld up a bracket to mount a small cart type wheel to the rear spring mounts.
And probably weld up something to come off the center subframe holes for the front.
If the rear were left in, you could attach a tow bar hitch to the front and tow it like a trailer.
Herb Adams did this one.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
Hey Teetoe...When I was restoring the body/subframe on my 69, I built a dolly out of 4x4's and castors. It was 36" wide and 48" long. I used a lap joint on the corners and glued/bolted the corners together and put 6" swival castors on each corner. That was in 94 and I am still using it on other stuff. The dimensions will let you bolt your body to the dolly thru the subframe mounts. It's cheap and works.
I've got a camaro 8.2" rear end and mono springs you can have if you want to pay for the shipping. Let me know.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
