1 - 2 of 2 Posts
68 camaro convet. ss 396, alt test out fine one bench, put new regulater on and still don't get 14 volts. I get about 11.5 to 12 volt. I replaced the wires going to the reg. but not help. On the starter swith was solid brown wire that was bur't and took it off. what's up help
I would replace the whole alternator with a one-wire alternator. Halls Auto at 800-848-2601 has one-wire alternators cheap. This will circumvent the field wire and the regulator; the only wire used is the thick red positive wire.
1 - 2 of 2 Posts
