I installed some new gages and changed some wiring around. Now I can start the car but it turns right off. I have a MSD 6 ignition. I seem to remember something related to the connection for the MSD. I know the small red wire is attached to a switched ignition. Which fuse on a 69 camaro is switched ignition. Any other thoughts on why it wont stay running. I have fuel injection also.
Check the ignition switch, one wire powers the coil when cranking then another when not cranking. Sounds like the one cranking is fine, or you may have hooked the MSD in the power from the cranking position wire?
is the IGN fuse on the fuse panel switched?
