still have issues with engine hot , smell of fuel and harder to start
I have the thick gasket plus added the heat shield and still have the same problem
did not have this problem a year or two before , nothing was changed
any suggestions
Do you have any non ethanol fuel in your area to try?
Reactions: 3forme
does your intake manifold have exhaust port (center) to carb?
If so you should block those. Edelbrock makes intake gaskets with metal plates blocking those ports
As above, you should
block off heat to carb
(Use Liquid Metal to close
off)
If you have a quadrajet,
they’re known leakers
at base.
No corn gas.
