i h:confused:ave a 700r4 trans connected to a bbc with the stock throttle rod.the tv cable wont work right with this set up.is there an easy way to convert to a cable for the throttle rather than the rod?
You should be able to get the throttle rod to work with the TV cable. Mine does.
You can use stock 6 cylinder parts for a stock cable or you can use Lokar cables etc.
