Hey all,
I think I already know the answer to this but I promised someone I would ask and make sure before we both go through a lot of hassle....
I advertised my 8.2" 2.73 geared rearend and someone called asking about the carrier. He has a '79 Camaro with an 8.5" rear but it's got something higher than 2.73's.... like 2.41? Something like that? Not sure. He's looking for a carrier that'll take 2.73 or lower gears. I guess he wants to go to at least 2.73. Follow me so far?
He got a '79 T/A 8.5" disc rear from the junkyard but it too has higher gears and won't accept anything lower than 2.41 (guessing at that number.)
He's wondering if the carrier from my 8.2 will go in his '79 Camaro 8.5" housing so he can change the gearing. I told him it won't but he wants to look at mine anyway. I told him he's gonna need a carrier that will accept 2.73 - 3.08 gears which mine will but like I said, it's 8.2".
He's out of luck buying mine isn't he?
Thanks!
Joe
WCA Member
1969 Wallet Crusher
- [email protected]
HwyStar's Garage!
You are right about the 8.2 differential not fitting the 8.5 rear end. The series break is also different on the 8.2 and 8.5 rear ends. The 8.2 uses a 2 series differential for the 2.73 gears where the 8.5 uses a 3 series differential for the 2.73 gears. He will be waisting his time looking at your differential. A new Eaton posi for his 8.5 is $348.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
Joe,
You tried to warn him and you even did a little research for him. If he is that hard headed sell it to him. Some people just don't get it. Why not just get one out of a 8.5 and know for sure it will fit? (I don't expect an answer to that). You got confirmation from a pro (Freddie), what more does the guy need?
Royce
I dunno Royce.... he hasn't called me back yet. He THOUGHT the T/A rears carrier would work because it's an 8.5", but when he popped the cover the carrier wouldn't accept 2.73's. I told him I'd swap him the 8.2 for the T/A rear because it has discs but I guess he's keeping some of the parts off of it.
I was gonna mention the Eaton setup to him but he seems stuck on saving $$ and getting a junkyard unit.
[This message has been edited by HwyStarJoe (edited 11-14-2002).]
'Round and 'round we go....
Just got off the horn with him again. He still wants to come look at my 8.2. I don't know why! I had to explain to him the difference between a differential and a housing. And that an 8.2 won't fit an 8.5 rear. I turned him on to NastyZ28 and he was clicking away at it when we hung up.
It boils down to him not wanting to spend the $400+ on an Eaton posi unit and install kit. He's returning the '79 T/A disc rear to the junkyard Sunday and wants to look at mine Saturday.
He offered me the T/A rear but I don't want the hassle and expense of having the welding done to it and the carrier change to make it fit my '69. It would be nice to have a disc rearend though!! Oh well... an upgrade for the future. I'll settle for the '73 Nova 8.5 rear I found instead!
It'll bolt right in.
Thanks again....
Joe
WCA Member
1969 Wallet Crusher
- [email protected]
HwyStar's Garage!
You can take the disc brakes off of it and put them on your rear end. I'm pretty sure they bolt on.
427/4spd/9"
Byars Performance
