segmented clutch materials, aka "puc type" made by various companies can be ceramic or carbon composite, Kevlar and even iron full face. Each has their benefit it either heat tolerance or friction minimizing. Trade off's can be in drivability and PP & FW wear on more aggressive material types. They all have a purpose over the other depending on use intent based on use purpose of car (drag race, street, drifting, autoX)
I campaigned a car on the Super Chevy tour years ago for a few years and went through several types of clutches so have opinions on the brands I have tried. Granted drag racing, with a tire, is absolutely brutal on clutches so failure was always a given. Under those conditions' guys, including me, who did have a CF clutch experienced the weights breaking which did make noise after. Likely not an issue in normal street use. My $.02 is if more friction holding is needed either use more aggressive clutch disc material and live with the downside of street manners if it is not an exclusive track car or get a dual disc, aka twin disc, clutch.
