I'll give you my take on lacquer....
It looks nice, but mainly when you see a lacquer paint job, it was for someone particular, hence the reason it looks so good, not that lacquer actually looks better.
I did some repair work on a show car that I previously painted in lacquer (14 coats color, no clear) & could no longer get the correct pigments for more paint.
I used PPG base/clear instead. When the car is detailed flawlessly, you see virtually no difference. Keep in mind this is only because I know it has been done & specifically try to find a difference.
After a washing or 2, the base/clear still looks the same & the lacquer has lost a little shine.
Keep in mind, lacquer is not a durable paint & continuously oxidizes to some extent... actually all paint does, but newer catalyzed paints do so at a much lesser rate.
Get bird droppings on lacquer & it will eat into the paint, as will water spots in some cases.
If you intend to drive it, lacquer is the last choice.
Trust me, paint has evolved over time & embrace the technology
I have no reason to ever paint another car in lacquer.
