1 - 2 of 2 Posts
My 67 (new to me) has developed a problem which hopefully someone can steer me in the right direction before I look in the wrong direction. She starts fine, run fine, shuts down fine. Go to restart her immediately after shutdown and she won't even turn over. The battery has a full charge during this period. Wait 1-2 hours and she starts up just fine and the whole scenario can be repeated. Any ideas?
It sounds like a similar problem that all chevy owners sometime at one point had. Your starter solenoid gets too hot and won't allow the starter pinion to engage.
Them after a period of time, when things cool off, it starts.
If this is the problem, they make a lot of different ways to solve the problem. The one I use on my big block is a remote ford starter solenoid. They sell this kit at Jegs or Summit or you can do like I did and make your own. Painless Wiring also makes a kit called Hot Shot. They make heat sheilds that bolt over the starter solenoid. There's a lot of options.
Good luck,
Bruce
1 - 2 of 2 Posts
