1 - 2 of 2 Posts
how do I reset the check engine light in a late 90's camaro I had the fuel injectors cleaned and it came on
Unless there's a persistent problem, the system will reset itself ( turning off the light ) in 3-5 start cycles. My 97 GMC occasionally triggers the light due to some intake mods I've done. If it's staying on, you might want to get the code pulled/interpreted to see if there is a problem that exists.
Rick Dorion
69 RS Conv,355,M20,4.10's
1 - 2 of 2 Posts
