1 - 20 of 22 Posts
Ok...guys this may sound stupid but what exactly is a chevy 355...Also approx what kind of hp can a 355 with a blower put out...is 500-600 streetable hp obtainable with this set up....Thanks in advance
[This message has been edited by Badcaiman (edited 08-27-2001).]
My 355 makes 437 rear wheel horsepower (around 500 flywheel hp) with an ATI Procharger pushing 9 PSI of boost thru a set of mildly ported L98 (Corvette) aluminum heads. So, the answer to your question is, yes, it is possible.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 4/16/01 at:
www.geocities.com/gheatly
A bored .03 over 350 would become a 355 in3(albeit slightly lower compression unless you shave the heads a tad. Did it to mine, with the cam from a 327, 375 HP - just got the carb straightened out, AWESOME!!
JJH
You can find out the size of a motor by this formula:
Multiply:
BORE x STROKE x PI x # of CYLINDERS
by the way
PI alway = 3.14
[This message has been edited by Black 67 (edited 08-29-2001).]
Lets do a Chevy 350
Multiply Below
Bore 4.00
Stroke 3.48
Pi 3.14
Cylinders: 8
349.67ci.
Don't want to get into a mathamatical feud, but BORE X PI X STROKE X #CYL, only works for 4" bore. The correct formula is 1/2BORE X 1/2BORE X PI X STROKE X #CYL.
It works for 4" because 1/2 x 4 x 1/2 x 4 = 4.
I don't want one either! I also do not claim to be a math whiz (not yet anyways but I am working on that) I was just trying to recall what was taught at the class that I took last semester out here.
The formula in our book is:
CID= pie x R(squared) x L x N
in which pie = 3.1416
R(squared) = bore radius or bore diameter/2
L = length of stroke
N = number of cylinders
This is were I have gotten my info.
"Like I said that is what I thought, I have been wrong before and will be again!"
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
[This message has been edited by idoxlr8 (edited 08-28-2001).]
to figure out the volume of a cylinder, you need diameter squared x pie x height. so that would equal bore squared (bore x bore) x 3.14 x stroke x number of cylinders.
[This message has been edited by lil_beast_67 (edited 08-28-2001).]
Bore x Bore x stroke x .7854 x # of cylinders...works every time
Byt he way, overboring an engine, with all else the same, increases compression, not decreases it.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
I may be the oldest ( or nearly the oldest) poster here, but way back in the old days I was taught that the area of a circle was calculated with the formula " Pi r2 ". Now if that is the area of a circle, then multiplying this formula buy the height of the cylinder will give the volume of the cylinder. That is "Pi r2 h ". This is the same as 3.14 x 1/2d x 1/2d x height. End of math class.
H-dog
the formula Travis posted works in every case regardless of engine dimensions.
bore x bore x .7854 x stroke x # cylinders
UNREAL:
Man I've been out of school for to long... Thanks for showing me why it only works with a 4 inch bore... I still can't believe I forgot the formula... Oh well..
H-dog, pie r round, cornbread r square!!
My last year of college I had to take Chemistry 101 as a required class. In the first lab we were learning how to calculate volume (duh-pretty simple task after 4 years of engineering classes) and we each had to take an object from a box, measure it, and calculate its volume. I chose a cylinder because I was lazy and only wanted to measure 2 dimensions. But our worksheet had spaces for length, width, and height. I only filled in two: diameter and height, then calculated the volume. When I handed it in, the TA pointed out that one of the spaces was blank. I explained that I had a cylinder and only needed 2 dimensions to calculate the volume. She began to argue with me that it wasn't possible and I needed a third dimension to find the volume of a cylinder!!! And this girl was a grad student?? I realized on the first day that I wasn't going to get much out of that lab class. The second class she came over and apologized and agreed that I was right, you can find the volume of a cylinder with just diameter and height.
Another way of looking at displacement (sometimes it helps me to derive a formula so I understand where it's coming from):
Find the area of the cylinder:
(bore)x(bore)x(PI)/(4) or
(1/2 bore)x(1/2 bore)x(PI) (same thing different way)
Then multiply by height of cylinder (stroke):
(bore)x(bore)x(PI)/(4)x(stroke) or
(1/2 bore)x(1/2 bore)x(PI)x(stroke)
Then multiply by the number of cylinders to find the total displacement of the engine:
(bore)x(bore)x(PI)/(4)x(stroke)x(# cyl) or
(1/2 bore)x(1/2 bore)x(PI)x(stroke)x(# cyl)
Note that the first equation is the same as Travis' because PI/4 = .7854
[This message has been edited by No 'E' in Camaro (edited 08-29-2001).]
My math teacher was right when he said "YOU WILL NEED THIS IN THE REAL WORLD" I just thought he was going mental... Of course he did walk up and down the halls with a leash in is hand, talking to an invisiable dog..
1 - 20 of 22 Posts
