I have two yellow wires under the dash that look like they went to the lighter. Are there two wires for the lighter and are they yellow? Could one possible be for a glove box light?
Cig lighter gets one orange wire only. Glove box light is also orange.
Yellow wires go to:
Heater control switch to heater resistor
Fuse block to radio power connector
Low fuel warning module to dash light
From dir signal switch through steering column connector, then through fisher body connector to L.H. tail,stop, & dir lamp.
Fuse panel to wiper motor
Starter solenoid to ign coil +
I think that's all the yellow wires except for what may have been used for accessories.
Check to see if your wires are allways hot or switched through the ignition. Trace them back to find where they originate.
Hope this helps.
