I just bought a external electric fan relay kit from jegs. Pretty basic wiring but it came with this small ugly circuit breaker the kind you find at the hardware store. 12v 30a. I was wondering if I would be able to put an inline 30a fuse instead? Its much cleaner and Im able to hide it in the loom. But I dont want to comprimise my fan,engine or both.
The system will be fine with a 30 amp inline fuse holder. I run a dual fan dual relay set up from Ron Davis and the relays supplied are Hella's w/ inline 30 amp fuses, they have a rubber enclosure around each one to keep them dry as well. If my memory serves me right the fuse holder pig tails should be minimum 12 guage.
Rich
Circuit breakers for large loads like fans is my preference. Fans can draw a lot of current when they first start. To account for the startup load, a fuse has to be oversized slightly. A circuit breaker is a bit more forgiving and will self reset if it does trip for some reason.
