1 - 11 of 11 Posts
has anyone used or had any expeirance with this kit. the part num is 500-661 in the catalog it looks to have everything needed. i installed car audio as a living for a bit, so i am famillar with wiring up 12 volt.
thanks
I have this kit. I haven`t installed it yet, but have went through it. I can say it is pretty much plug and play. There are a few wires that you have to terminate, but it comes with all the neccessary connectors and plugs. Very complete wiring harness. With that being said, my car is a 67 rs, so I still have to buy the front light harness, which is not included in the kit you mentioned. If your car is a 68 or standard 67, then it comes with the neccessary front light wiring harness.
That kit is made by American Autowire, makers of the best GM harnesses. We install a lot of these Classic updates, 3 are being installed right now as we speak in our shop, and have sold many to Team Camaro members.
We also sell them for less then Classic. $475
Hey Jeremy when you are ready for the r/s add on I have one I purchased and didnt use I could sel you. I ended up using the retro electic motors and didnt need it.
One more quick question for Frank--on the Classic Update Harness-p/n 500-686-- do you have to terminate the wire ends for each component? such as headlights, park, turn signals, etc?
Thanks for all of the great advice on this site
Dan
:beers:
You will terminate ends for Headlamp wiring, taillight woring, etc. This is because there is extra length for those wanting to run wires hidden under fenderwells, etc. 80% of the kit has the plugs and pull offs already in place.
It is not a difficult install, but is not plug and play like repro harnesses are either.
1 - 11 of 11 Posts
