Font Bag Fashion accessory Bottle cap Eyewear
Cleaning house. Miscellaneous parts for sale. Inexpensive. PM me with reasonable offer if you can use something. Happy to take additional pictures.
  • Napa Power Steering Return Hose #7-1622, New in box. Fits list below. -
BuickApollo5.7 L 350 CID V81975 – 1975
BuickSkylark5.7 L 350 CID V81975 – 1975
Ford TruckBronco2.8 L 170 CID L61972 – 1972
Ford TruckBronco3.3 L 200 CID L61973 – 1974
OldsmobileToronado1977 – 1977
PontiacFirebird5.7 L 350 CID V81968 – 1969
PontiacFirebird6.6 L 400 CID V81968 – 1969
PontiacVentura4.3 L 260 CID V81975 – 1975
  • Tub of SBC/BBC Misc. Original GM Older Engine Bolts
  • Standard Motor Products DR-2270XP ignition point set and DR-70X condenser. (High performance set no longer made) Condition: New in box.
  • Summit #SUM-402035 Chrome BBC fuel block-off plate
  • Early GM coil bracket fresh satin black powder coat
  • Late ‘60’s GM coil bracket
  • Various PCV valves. New in box.
  • (3) Fram FV181 – ’65-’72 SBC & BBC Except Special Hi-Perf
  • (1) FV295 – ’94-’00 S10 2.2L & ’89-’97 4 cyl. Chevy cars
  • Performance Stainless Steel Heater Hose Fitting #1041, ½” NPT by 5/8” Hose Barb, 45 degree
  • Ricks Camaro lower fan shroud mounting clips for ’67-‘69 F body – Pair, New
  • Mallory SBC/BBC Unilite Distributor #3748201D – needs module
  • Cast Iron Distributor 1111016 Date Code 2 G 5. (July 5th 1962) I believe this came out of an old 283. Nice condition
  • 1959-1970 Full Size Pontiac Proforged Upper Ball Joint #101-10002 – New in box
  • Set of 3/8-24 Poly Locks. Good condition. These are old. I haven’t run anything with a small block since early 80’s.
  • 1 ½” Radiator hose Connector - Used
  • Chrome Valve Cover breather - Used
  • Summit Racing Chrome BBC Fuel Pump Block Off Plate - Used
  • GM 24205373 TH400 Kickdown Connector - New
  • (1) GM Astro Ventilation Connector Tube - Used
  • Aftermarket Stock Coil - Used
  • Various Ballast Resistors - Used
  • ’67-’68 F Body Trim Parts Steering Column Seal-New
  • Hayden BG-210 AC Cooler Mounting Kit – New
  • (2) Sets Battery Terminals
  • TCI 880018 700r4 15 Tooth Speedo Drive Gear - New
  • GM 1362293 TH400 40-45 Tooth Sleeve – New
  • GM 1362196 700r4, TH400 43 Tooth Speedo Gear – New
  • GM 9780470 700r4, TH400 44 Tooth Speedo Gear – New
  • ’68-’69 F Body Throttle Linkage Arm, Aftermarket – New
  • 3 ½” x 2 ½” Header Collectors & Bolts – New
  • 1967 F Body LH (I think) Windlace Cap + some extra clips
  • 1946 Pontiac “Pontiac Eight” Emblems – Pitted
  • Pair, 1968 Firebird Interior Quarter Panel Stainless Trim GM, (1) Upper Door Panel Trim, Pair Door Panel Firebird Emblems
  • (1) Quarter Panel Ash Tray GM – Pitted
  • (3) GM Body Plugs
