I've got two tanks, one that had some holes and filled in with j.b. weld, and another that altough has some dents is fine, except it's got some crap inside of it, whats is the best way to clean it out? or should i use the other tank, doesn't seem to leak.
Thanks Ryan
DON'T use the patched one...it may not leak right now, but that spells T-R-O-U-B-L-E later on.
Have a pro clean out your tank. It must be opened up, cleaned out and re-welded together. They can properly evacuate the tank before doing it. Otherwise you may bloe yourself up!
1973 Type LT Camaro ...the daily driver
1968 2 door sport coupe...the toy!
1970 Chevelle SS396 (L34)...numbers matching, all original!
The Monday Nite Car Club!...our car club
American Muscle Cars...as seen in Super Chevy, THE resto shop in SoCal
Check how much it will cost to have it cleaned. It may be worth it to buy a new tank by the time you figure the cleaning cost.
Dean
Racer#00
67 Camaro (Almost done!)
76 Trans Am Stock Car
68 Dodge D-100 P/U
For the cost of a new tank I don't think it would be worth the time and effort to even mess with an old one, not to mention the piece of mind knowing that you will probley not ever have to worry about it again.
I've seen new tanks on e-bay for less than
$150.
well.... you could always use a match
