1969 Camaro
Is there a good way to remove or repair clear on aluminum wheels? If I can get it off, and pollish them, then I would keep them.
Better try it on some scrap aluminum before you use it on your wheels. I think oven cleaner is lye based, and lye eats aluminum.
From http://www.easyoff.us/faq.shtml
Can EASY-OFF® Heavy Duty Oven Cleaner be used on any aluminum?
We do not recommend using this product on aluminum, as it may pit and discolor it. However, it does not penetrate into the metal or remain on the surface after the recommended rinsing instructions have been followed. Utensils and appliances cleaned with EASY-OFF® Heavy Duty Oven Cleaner are completely safe for use in cooking or serving food after they have been thoroughly washed and rinsed in a vinegar and water solution.
