I have a 69SS originally an AC car, but I'm putting in Vintage Air. The engine is not original and came with a 6 blade flex fan with about a 2 inch spacer in front of the water pump, a shroud and no clutch. Can I just put a clutch on it? And which set up would be best? Is it better to use a clutched fan or not? For power? For reliability?
As you can see, I don't know a lot about clutch fans. I will read my assembly manual while I wait for responses to see what insight I can glean from the original set ups.
Thanks,
John
Thanks,
John
