When depressing the clutch pedal a "clicking"
noise is heard, it increases when RPM is raised. No noise is heard when car is in gear and driving....any help out there for this problem? thanks
you didn't say what year the car is. if its a 4th gen camaro, clutch noise is a very common problem, the only fix i have seen yet was when one of the hot rod mag's replaced the clutch with a centerforce, the noise went away. g.m. has no fix for it, but if you have an older camaro, yes, it sounds like a throwout bearing
67 RS
355, SUPER T10 4 SPD
9" FORD
