I have a white wire coming from the engine harness that I think is supposed to go to the Coil. I have replaced the old engine (6cyl) with a 350 w/HEI. Does this wire go to the distributor?
67 Coupe
<UL TYPE=SQUARE>
<LI>ZZ4
<LI>12 Bolt Auburn Posi
<LI>4-Spd
<LI>reassembling it now
[/list]
The wire that went to the + side of the coil on the six banger is more than likely a resistor wire. You don't want to use that on an HEI. Run a 14 gauge wire from the IGN terminal on the fuse block to the HEI. That should get you up and running.
'69 RS Camaro
355 5-speed 4.11
Thanks alot. Electrical is not a real strong part of my abilities. But thanks to you and alot of guys here on this board, my project is coming along.
67 Coupe
<UL TYPE=SQUARE>
<LI>ZZ4
<LI>4-Spd
[/list]
