I have dyed many interiors...Though I have never used the VHT bombs..You can buy a qrt of the same paint for what you pay for 3 cans..But you would need a spray gun...
But here are some recomendation..
#1..Make sure you clean all the pieces..prepsol works best..When you think it is clean..CLEAN IT AGAIN..You want to make sure you take all the silicon(sp?) off...(Paint and silicon don't mix)..
#2 Make sure you have good temp and that humidity is low..Those spray bombs seem to react poorly to high humidity(Whitish dull haze)
#3 last but most important with interior dyes the less you use the better...So a light coat let it flash and then another and that should be it...To much and it loses it flexibility and cracks..
Good Luck
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
