Donor car - 1968 Chevrolet Camaro
Running video -
Car was in an accident and I bought it to use some parts for my car and part out the rest.
Fully Loaded Speedtech Total Chassis Suspension Driveline System
-Front subframe has a dent and components throughout kit may need to be straightened/repaired.
Solid Body Mounts
AFX Spindles
C6 ZR1 Wheel Hubs
C6 Z06 6 Piston Brake Rotors
Viking Performance double adjustable Coilovers
Adustable Upper Control Arms
Tubular Lower Control Arms
Rack and pinion Steering (Bent Tie Rods)
Extreme Duty Sway Bar
DD Splined Steering shaft
LS3 6.2L Crate engine purchased from GM
Stand alone wire harness with fuse box (some wires were cut at removal)
Custom Grind Cam from Trick Performance
Upgraded Rocker Trunion
Upgraded Valve Springs and Pushrods
Speedtech Performance Long Tube Headers with 3" V-Band Exhaust
Vintage Air A/C Compressor, Power Steering, Alternator, Mech. Water Pump
Extreme Duty Remote Oil Filter Housing
T56 Magnum Transmission
Quicktime Pro Bellhousing
McLeod Twin Disc Clutch
Custom Aluminum Driveshaft
Tremec Shifter
12 Bolt Rear axle
Rear axle has been bent from the accident
Watts link chassis frame was welded onto chassis on top of bolting on for increased rigidity. We left this on chassis so it is not included (can be purchased from Speedtech)
Eaton Posi with 3.73 Gears
C6 Z06 rear brakes
Parking Brake
Viking Double Adjustable Coilovers
Watt's Link
Running video -
Solid Body Mounts
AFX Spindles
C6 ZR1 Wheel Hubs
Tremec Shifter
12 Bolt Rear axle
C6 Z06 rear brakes
Parking Brake
Watt's Link
