What is the norm for compression on a 327? Just wondering. Thanks
Is the 327 from a Camaro? If so, is it the LF7 (327, 210hp) or the L30 (327, 275hp)? Static compression on the LF7 is 8.75:1 I believe whereas it is closer to 10.25:1 for the L30.
Discussion Starter · #3 ·
I have 150+- 5lbs in each cylinder. Is that normal?
I would say, yes, that's good.
Steve
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
As long as your within around 10 psi of each other, you are usually pretty safe. You don't normally loose pressure in all cylinders unless the motor is really hosed.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
