1 - 15 of 15 Posts
Alright, here's my problem. I've got this nice 1967 camaro 327 40over w/ an awesome roller rocker set in it. But its not cranking out the power i want, so i think i want to put in a new more aggressive cam. Im not sure what i sould put in, but ill get to that later. All the websites like ISKY cams, Comp Cams, and Crane Cams rate their cams by the compression. I dont know what the compression is because all the engine work was done before i got the car. Can anyone tell my how to find my compression???
Banned
The easiest/hardest way to do this is to chase down the guy that built it and ask him what the motor has in it!! Hardest = probably can't find him...
Otherwise, post back the letters at the end of the VIN number string that is on the pad above the pass. side top water pump bolt and we will try to decode what it is IF it is still a "virgin"... The letters will be between "MA" and "MN" if it is a '67, 327 motor...
Also pull a valve cover and post back the long casting number between the valves so we can help with what heads are on it too.... That number should be like "3891462". It's the last three numbers we look at.. The "-462" here..
If it has been "molested", you will have to pull a head and see what pistons are in it
I have a feeling that if it idles nice and smooth you have a low compressioned, 210hp jobber and about the only way to perk it up is to install a set of 64 cc heads on it and then a good old CC 268HE OR Crane 272/272 Energizer hy-cam along with a set of cheap, 1.625" four tube, long headers and a 600 cfm Holley 1850 carb. on a Holley 300-36 hi-rise intake!!
Then she will run like a "scalded-dog" if geared and tired right.. At least my .040" over 327 did...
pdq67
is there a way to tell off of cylinder pressure with a compression tester?
Sorta, but not really. The closing point of the intake valve has a huge effect on this ##. If you knew what cam's in it, then yes, otherwise, not really. You could check it and see where it is... pretty much, with a near stock cam, under 150 = "lazy" 150-180 = "normal" over 180 = "hot"
The info asked for above will help some. If you can see a piston top thru a sparkplug hole with a flashlight well enuf to determine if it's flat, dished, or domed, that'll help too.
Could always work it backwards... fill it witl 87 octane, and keep advancing the initial timing till it starts pinging
Yes there is a formula.your compression lets say is 160:327x2=0.9785932 this is almost 10 to 1
if 180:327x2=1,1009174 this is 11 to 1
hope this helps Nick
: this means divide
Huh.... 160 and 180 are psi. 327 is cubic inches... I'm not following.
Like the others have said the only way to determine the static compression ratio is to look at the pistons and know the combustion chamber size, head gasket thickness, etc. etc. etc. If you take a compression reading it is more closely related to the dynamic compression ratio (DCR). If the compression reading is down (i.e. below 160) a larger cam (later intake closing event) will hurt the performance rather than help. You really need to match the cam with the static compression ratio and target an 8:1 DCR for iron heads or an 8.5:1 DCR for aluminum heads.
Yes, 160 and 180 is psi and 327 is not an engine, its a number. times 2 will give you your compression ratio. You can call it dcr or watever you want to call it, at least you will have a number that is close to the compression ratio. If the engine is worn out, then yes, the numbers will be out, but if the engine is fresh, I would say its very close. So take your compression, divide it by 327 times 2. That is the formula. I was given this by an old machinest. Nick
Well let's try the forumula. I have a 414 (402 +.060) that's running 9.7 static compression and 7.95 dynamic compression. On a compression test it pumps out about 175 psi (varies a little cylinder to cylinder). So the forumla is (175/327)*2 = 1.100917. So this is saying I have an 11:1 motor??? :eek:
The only way to know for sure is to remove a cyl head. Measure the volume of the chamber, measure the deck height, and measure any dish or valve notches in the pistons, and determine what kind of head gaskets it has. (Hopefully you don't have domed pistons.)
An educated guess method would be to determine chamber volume from a casting number on the head. You might be able to shine a light into a spark plug hole and see if you have flat top pistons, dished or whatever, and figure it based on some assumptions. Problem is, you can't really tell if the head has been milled or if the block has been decked, and those have a pretty big impact on CR.
If I couldn't track down the info from the builder, I'd pull a head and measure. Once you have it torn down far enough for a cam replacement, it's not that much more work to pull a head.
Compression ratio calculators are easy to find on the web - just do a google search. But they are worthless if you don't have accurate data.
rpol, while I'm not buying the formula, except maybe for stock cam grocery getters, I think the "327" should be replaced by the actual displacement of the engine in question. Doing it that way, I get 8.4:1 for your 414. off just as far, other direction...nope, still not buying the formula thing...
Hey JimM At the time i had a 67 Camaro with a 327 so when I asked the guy he told me to use the 327 # so maybe the 327 is the displacement # I don't know but it is ease to find out by doing some # of engine displacement and engine compressions and see what comes up.Nick
Using the formula posted, it doesn't work out on the recent 355 I built. The cyls were c.c.'d @ 64. Going through the formula for mechanical c.r., I got 10:3. Here is my numbers in your formula; cyl. pres=205 divided by c.i.d. times 20 = 11.5. Now, if i use the same formula, and times it by 18 instead of 20, I get a more realistic answer, 10.39 or 10.4. If this formula worked for more than a few motors with a KNOWN c.r., then I mite buy into it, but I wouldn't put much faith in it without a reasonable amount of research. If anybody else has a known (key word) compression ratio 355 cu. in motor, plug the #'s in see what you get. Allways remember, "you can't go wrong, when you do it right".
19ynot52 i agree with you about taking the head off to find out the correct cr, but he was looking for an easy way to do it without taking everything off. Weather this formula works or not, its up to everyone's finds. maybe if 18 works better than 20, then maybe that is the answer. We are just trying to help each other here, and im not trying to misslead anyone. To tell you the truth, those numbers were given to me in 1974 when i had my 67 327 275 hp car and believe me, i had to think very hard to try to remember what the numbers are, but i knew the 327 was one of the numbers because it matched my engine. Anyways, if it works, fine, if it doesnt work, take the heads off. Nick
1 - 15 of 15 Posts
