1 - 12 of 12 Posts
396 with the 325hp and has edelbrock 454R-head part 6055 along with cam,intake, and holly carb. What is the comp. In the motor and what should each cylinder comp. Be around when I do a test. Also where should my timing be and how much HP. Should it make. Thanks
Do you mean the Edelbrock Performer RPM 60555 head? If so that has a 118 cc combustion chamber and 315 cc intake runner.
Do you have stock pistons in the 396? Standard bore?
Yes the 6055 kit stock pistons and bore
Joe,
I'm going to guess your compression is around 8.18 to 1 with a Felpro .031 head gasket...With a steel shim gasket .020 would give you around 8.33 to 1...
Bore: 4.094
Stroke: 3.76
Cylinder head Volume: 118 (This is hurting your compression)
Effective Dome Volume: -17 (ball park for the 10.25 pistons)
Head Gasket thickness: .031 for Felpro (steel gasket would be around .020)
Deck Clearance: .025 (OEM pistons)
Holy Mis-Match Batman !
Just kiddin' but those huge intake ports on a 396 will result in very poor low-end torque.
Better to come here and ask for advice before buying parts.
Discussion Starter #10
Didn't buy them came with the car. I would have asked my engine builder Joe at J&E performance in Blackwood nj. But then I would probably have gotten carried away and went all out on something radical lol.
Those heads are worth a lot of $$$ so you can always trade or swap for whatever you need.
Yep, and a set of smaller combustion chamber heads would help bump up the compression.
1 - 12 of 12 Posts
